Hi, sorry if this is a bit of a noob question... we just moved into a flat in a block of , and the staircase for the block is exernal. There's lights running up itn- though more than enough light comes off the street - and all of them are connected to our mains, rather than shared out or on a separate supply. To make matters worse there's only 2 switches, one just inside our front door and the other at the bottom, so even if the other flat wanted to turn them off at their front doors they can't.
Turning them off at the switchboard isn't possible since the switch that controls them also controls the internal lights and the plug sockets. But I thought, what if I undo the lightswitch in our house and just disconnect one of the wires? So firstly - will this stop the lights being turned on and using our power, and secondly, is it unsafe just to wrap the disconnected wire in electrical tape and leave it in the socket?
Cheers,
Cheers,
