Decorative panels with no fixings are ok but those with fixings which need unscrewed tend to be the problematic ones. Would it be so hard to call the manufacturers helpline to check?
In a word yes, clearly the electrical regulations mean you must have a tool or key to remove panel, and clearly one does get to know which panels are for decoration and which are connected with the balanced flue sealing, and if you can access the installation instructions then clearly one would look, this
is clearly some thing we need to know. It the boiler requires at type A
then we need to ensure type A
is fitted not type AC
so if available we would glance at the installation manual, however that is only possible if the installation manual has been left with the boiler, here in Wales hard enough to get mobile coverage never mind internet, and clearly there should be a Corgi only or Gas Safe only sticker on the boiler, and if there is it can be given a code FI and the customer told you need the boiler checking by a gas safe guy or a Code LIM and put on report all items marked Gas Safe only are outside of this inspection.
However if some gas safe guy has failed to put a sticker on the boiler we must assume you don't need to be gas safe to remove cover, and on most it is clear did not need to be gas safe as one can see some where some gaping hole, clearly if gas proof then gas proof glands are used, and it will not be supplied with twin and earth etc. So in the main it is clear when the cover is forming a seal.
Before the new landlord law in England the EICR was only for the installation, electrical equipment be it fixed or portable was covered by the inspection and testing of in service electrical equipment, so EICR covered lights but not the bulb, and wiring, and overloads etc, but not the extractor fan, immersion heater, built in oven, etc. And in the main built in equipment was covered by some maintenance contract, be it freezer or oven or boiler, so up to now the boiler wiring stopped at the socket or FCU, but now the new law says any fixed electrical equipment should come under the EICR, I think totally wrong, but not up to me, new law says we must inspect.
