    Dismiss Notice
Dno isolators Switch only single poll
Discussion in 'Electrics UK' started by Mattrm, 9 Jan 2019.
  1. Mattrm
    Mattrm
    29 Dec 2017
    20
    Thanks Received:
    Scotland
    Country:
    is it standard practice for DNO isolators to only switch the live cable from the meter?
  2. AndyPRK
    AndyPRK
    4 Jan 2009
    3,973
    Thanks Received:
    357
    Herefordshire
    Country:
    Not if it’s a seperate isolator
  3. Mattrm
    Mattrm
    29 Dec 2017
    20
    Thanks Received:
    Scotland
    Country:
  4. AndyPRK
    AndyPRK
    4 Jan 2009
    3,973
    Thanks Received:
    357
    Herefordshire
    Country:
    I see what u mean
  5. SimonH2
    SimonH2
    4 Nov 2010
    5,175
    Thanks Received:
    530
    Cumbria
    Country:
    It seems to vary even within the same DNO - in my case ENWL.
    At the rental house, it's single pole with a Henley block for the neutral connection. The isolator is 2 pole, but there are labels shouting out that 2 of the terminals should not be used.
    On the other hand, last year I had them come and fit an isolator for me - and that's two pole switching both L&N.
  6. AndyPRK
    AndyPRK
    4 Jan 2009
    3,973
    Thanks Received:
    357
    Herefordshire
    Country:
    Why have they even fitted that N block?
  7. SimonH2
    SimonH2
    4 Nov 2010
    5,175
    Thanks Received:
    530
    Cumbria
    Country:
    How else does the sparky replace the neutral tail (or whatever) without breaking the seal on the meter ?
  8. AndyPRK
    AndyPRK
    4 Jan 2009
    3,973
    Thanks Received:
    357
    Herefordshire
    Country:
    Supply fitted before cu I guess
  9. Mattrm
    Mattrm
    29 Dec 2017
    20
    Thanks Received:
    Scotland
    Country:
    The meter was fitted shortly after I moved in (November 2018) as I had requested the energy supplyer change the prepayment meter to a normal one
  10. aptsys
    aptsys
    16 Sep 2007
    1,589
    Thanks Received:
    114
    Cambridgeshire
    Country:
    It's fairly common.
  11. SimonH2
    SimonH2
    4 Nov 2010
    5,175
    Thanks Received:
    530
    Cumbria
    Country:
    Shouldn't matter since a significant reason for having the isolator is to allow for maintenance. So whether the supply is in before or after the CU shouldn't have a bearing on providing a means to disconnect/replace the neutral tail without breaking meter seals.
  12. Screech20
    Screech20
    9 Sep 2013
    349
    Thanks Received:
    8
    Sussex
    Country:
    I’d be more concerned that it’s not fitted to a proper meter board.
  13. SUNRAY
    SUNRAY
    28 Jul 2009
    1,592
    Thanks Received:
    76
    Kent
    Country:
    Simple, he didn't have enough blue tail on the van.
  14. AndyPRK
    AndyPRK
    4 Jan 2009
    3,973
    Thanks Received:
    357
    Herefordshire
    Country:
    he didn't come with very much then, if it won't even reach the isolator!
Loading...
Share This Page
