Toyota RAV 4, 60 plate.
Drivers door window stuck halfway down but was attempting to move, so:
Door card off, mirror off, noticed the glass had jumped out of its front channel and was solid.....slackened everything off I could see and heaved the rubbers out of the way.
At this point I noticed that the front window channel was heavily distorted because the door open check mechanism had caught it at some time when the door had blown back
Managed to release the glass and pull it out and set to work pulling the channel back into shape with slip joint pliers, mole grips and a short wrecking bar.....two hours later it was as straight as I could get. These channels are welded in front and back, so no replacing them
Put the glass back in but with the window down the check mechanism was scraping against the glass, so back out with that and gentle work with the grinder.
Sorted! Plenty of silicone spray on the runners and put all the trim back, working great.
Finally had to adjust the door striking plate which could indicate that the entire door may have distorted slightly.
Quite a day....hands and wrists are shredded now, many sharp edges.....I’d never thought a door blown back could wreak such havoc.
John
John
