markplumb said:Don't teach people cowboy tricks then. that's what it boils down to. would you expect this type of work from say the gasboard?
No, they'd try and sell them a new boiler...
No, once again, you are wrong on both counts.unlike you it seems i live in the real world and don't resort to cutting couplings in half or dotting pinholes with solder and where did i say to PLASTER it over again? i'm guessing your a builder am i right or someone who hasnt been on the tools for years
me climb of my big horse. why shouldn't compression fittings be used as long as they are done corectly and with the right fitting of course?megawatt said:MarkPlumb???? wrote:No, once again, you are wrong on both counts.unlike you it seems i live in the real world and don't resort to cutting couplings in half or dotting pinholes with solder and where did i say to PLASTER it over again? i'm guessing your a builder am i right or someone who hasnt been on the tools for years
My advice to the OP was to ignore your stupid advice and to wait for someone with a degree of experience and common sense to advise how to do it correctly ... Chase out either side, remove damaged section, replace with new/slip couplings, prove and restore the finish.
I DO NOT recommend compression fittings in wall chasings and neither does any other pro (or even non-stupid DIY'ers) that I know.
If you are going to give advice to people who probably don't know any better at least consider what you are saying.
Now climb down off your big high horse and go read some plumbing manuals ... Fool.
MW
doitall said:Talking of tricks a well know poster of by the name of Argile came up with a brilliant repair.
Clean the pipe and flux it.
Wrap copper wire around the pipe about 10mm either side of the hole.
Solder it all together.
Yes and it does work with no cutting out or hassel, you just need to get all the water out first.
doitall said:You cannot bury compression fitting. Regs dear chap![]()
I still didn't work out if you are a builder an electrician or a fasttrack plumber, though i'm geussing you don't fit into any of them at all
markplumb said:doitall said:You cannot bury compression fitting. Regs dear chap![]()
lol you should have been here when people were cutting couplings in half![]()
megawatt said:Thanks DoItAll for the sanity check I doubt MarkPlumb would have ever got there![]()
From the quality of your advice I think I was correct with MarkGardener![]()
MW
doitall said:markplumb said:doitall said:You cannot bury compression fitting. Regs dear chap![]()
Nothing wrong with that if you can solder, the patch will be stronger than the pipe.![]()
