... similar, I imagine, to the reason why supersonic fighter jets (and, I imagine, Concorde in its day!) have after-burners, rather than double-size engines and/or twice as many engines.
Kind Regards, John
No need to imagine any longer!
Kind Regards, John
As we have now landed on subject of concord, and jet engines, one thing I have found hard to believe is the fact how a turbine engine compresses air to something like 25 to 1, and it completely amazes me and defies logic since all the blades on a turbine engine spin at the same rate, so how does it logically compress air, when truly speaking when the first set of blades move the surrounding air they simply pass that to second set of blades, which in theory should just allow the air to move to the next set of blades, and since the rear of a turbine engine is open ended, how does it manage to compress so much air, I could understand if the second set of blades were spinning at different speed or in an opposite phase such that air is forced to compress. I have always felt the need to understand why air can simply get compressed merely by number of sets of blades spinning at the same speed and in the same direction. logically I would not even have thought that this could work, it is like a chain of people (representing sets of blades) the first person passes an object to second and second to third and so forth, in the end the last person will only be passing out a single object and not two or twenty objects. Unless the design of a turbine engine is such that the first person is able to pass more quickly than the last person in the chain is slower than all, so this causes a bottle neck , so could the first set push in more air than others sets not able to handle the incoming volume of air and eventually the last set of blades pass out limited amount of air under great compression, I would love to hear from anyone able to explain logically how air can be compressed by means of blades all revolving at the same speed on the same shaft..
Many thanks, I see the logic if the end gets tapered and other blades sets have different number of blades and angles etc, so this is where the trick lies.Because the blades get smaller (shorter), and thus the casing gets smaller. The opposite happens in a steam turbine where the steam hirst gets shoved through the smallest turbine and then through increasingly larger blades to get more work out.
What will really blow your mind about turbine blade tech (in a jet engine) is how the melting point of the steel turbine blade is lower than the temperature of the combustion products... and yet they don't soften and stretch or come in contact with the outer casing at such high rotational velocity
Nozzle
I've not necessarily suggested that you have!I'm not sure I have been proved totally wrong in that the article Mike linked...
The systems certainly do their best. However, if detonation occurs (due to temperature and pressure) significantly before TDC, then no amount of 'tuning' (whether of timing or whatever) can do much, if anything about. Indeed, ignition timing (and, indeed, the spark itself) is obviously totally irrelevant if detonation occurs before the spark..... says things like can lead to detonation and they are a huge aid in tuning out the detonation so, presumably the turbo can provide a higher boost than without an intercooler - as must have been the case before them. ... Modern engines have knock sensors (as well as all the others) and adjust the timing accordingly and so all things are balanced to provide the optimum performance.
I would certainly question whether that is the "main" benefit, but it may be a factor.The main benefit of the intercooler is, as I have said, increasing the density and, hence, the oxygen content of a specific volume of air. This will slightly reduce the compression but obviously this lower compression will have been designed to be the right amount.
That makes sense, although it's the first time I've heard of it being done. However, given that this issue arose in relation to power-to-weight ratios, one thing those cars cannot do is 'switch off' any of the engine wight at low speeds/loadsWith regard to the query about the engine performance at low loads and speeds, some larger engine cars do indeed cut off half the cylinders when this is the case - thus halving the size of the engine when not needed.
Did it really use after-burners to take off? I must say that I thought it only used them to accelerate to supersonic speed.No need to imagine any longer! ... <Concorde take-off>
Is that what you are not grasping?If one cools air at constant volume (i.e. if it is contained in a sealed container), the mass of air (or oxygen) within that fixed volume, hence the density, will obviously remain unchanged no matter what one does to the temperature. Only if volume is allowed to change can a change in density possibly occur.
