Ensuite shower - tanking, or just tiling?
7 Oct 2009
London
I'm going to fit an ensuite, 1m deep by 2.4m wide, usual layout, sink in front of door, toilet and shower to either side. Shower will be 1m x 0.8m.
I was initially thinking wetroom style, but given the restriced space, it would still need a shower door/screen. I therefore thuoght I'd prefer a low profile shower tray, with the door/screen attached to the wall.
Question is, how would I ensure watertightness? Would tiles/grouting on regular plasterboard be sufficient (assuming shower tray/silcone sealant)?
What are the walls constructed of, stud & plasterboard or brick & plaster? Is it a new room?
All walls surrounding the shower section will be stud+plasterboard. The only brick section is on the outside wall, where the toilet will be
Prime the P/board with Bal Prime APD, then trowel the wall with rapid setting single part tile adhesive (4mm notched trowel) then apply Homelux or Schluter Kerdi tanking membrane, then apply a section of matting in the internal corner(s) with a 2" overlap onto your existing sheet. Tiles can be fixed straight away, no need to wait for adhesive to set. This tanking system will provide a 100% waterproof guarantee
