Extending TV power lead cable rating question
20 Aug 2019
I'm wall mounting my TV, however the power lead is too short.
The current cable is H03VVH2-F 2x0.5mm2.
1. Can I attach 2x0.75mm2 cable to the original cable? The 2x0.75mm2 appears more readily available?
2. What is the best/suited junction-type connector for the cables?
Thanks!
To join the two pieces, it's something like this:
%5B05110%5D%20Flex%20Connector%20Solid%202%20Core%205A%20Resilient%20White
https://www.lampfix.co.uk/shop/product/05110-flex-connector-solid-2-core-5a-resilient-white-5150
Well yes.
Of if it’s a figure of 8 connector, have a look on eBay to see if you can buy a complete length with connector and plug for a reasonable price to replace what you have now
Or if it's an IEC (kettle plug) type, you can buy longer versions of those, or IEC plugs to fit yourself - add a suitable length of 3 core, plus a 13amp plug.
Thanks, the cable is wired directly into the TV so no fig 8 connector or IEC.
I will have to cut the wire and extend using a connector I believe. I was just unsure whether a 0.5mm2 and.0.75mm2 wire can be mixed and connected together. I was unsure if this is a safe decision.
