You just can't do it can you. Why write a word when a sentence will suffice
That's dead right - except when I believe that a single word tells the whole story ... and I'm certainly not ashamed of wanting to give a 'full answer'.You just can't do it can you. Why write a word when a sentence will suffice![]()
...but then go on to say...Decrease (slightly) ...
... which is exactly my positoion.So I think it is very very marginal as to whether they increase or decrease safety.
Indeed so. A young relative of mine was very adept at (an passionately interested in!) unscrewing things, with real or improvised screwdrivers, from an extremely early age - and on one occasion was found three-quarters of the way through removing both attachment screws from a double socket. I guess that might have caused some people to call for a ban of accessories with slotted-head faceplate screws.My boys find a way of "posting" anything into anything. On holiday the way they interact with the European sockets really scares me.
...and, more important, educate about the need, tedious though it is, to 'oversee' what small/medium-sized children are doing at all times. No matter how much 'banning' (or advising people what not to buy) we do, there will still be countless ways (many of which we might not even have thought of!) in which these little people will find to do harm to themselves 'in the blink of an eyelid'!I think they should be not banned; but people should be educated to the complete waste of space and money that they represent.
A good question, which I keep asking - or, more precisely, whether is any (just one?) well-documented case of a child ever actually coming to harm as the result of use of a socket cover. If the lack of responses is anything to go by, I suspect that may never have been such a case.Has any child ever opened a socket with one of these; really?
I'm sure I read once (in something authoritative), that if it hadn't already been in use for millennia and a scientist discovered that sodium chloride had good flavour enhancing and food preserving properties, no way would it pass any safety tests for use as a food additive.as I've already mentioned, seatbelts and nearly all medicines would probably be the first things to be outlawed.
You'll die without it.sodium chloride
Very probably. In terms of drugs, things like aspirin and paracetamol probably wouldn't stand a chance in hell of being 'allowed' if they had first appeared in 21st century. However, that's because standards and attitudes have changed such that, in general, we now demand a very high benefit-risk ratio for such things (unless there is no alternative treatment, in which case any benefit:risk ratio >1 is worth having).I'm sure I read once (in something authoritative), that if it hadn't already been in use for millennia and a scientist discovered that sodium chloride had good flavour enhancing and food preserving properties, no way would it pass any safety tests for use as a food additive.as I've already mentioned, seatbelts and nearly all medicines would probably be the first things to be outlawed.
Alcohol and tobacco are no-brainers. If either had appeared in recent times, they would undoubtedly have been banned, and quite probably classified as "Class A" drugs.What if alcohol had just been discovered?
Yes they have, without doubt. See http://www.fatallyflawed.org.uk/html/user_comments.htmlDecrease (slightly)
Hence, if it were the case that they resulted in the death of one child every year but prevented the deaths of two per year, that would, at least in objective terms, be an adequate argument for encouraging their use, not banning them.
You'll die without enough calorie intake per day.You'll die without it.sodium chloride
Very true, but this recent part of the discussion spawned from RF's question as to whether socket covers currently available in the UK increased or decreased danger. Since my understanding is that most of the currently available products would not comply with the proposed requirements, I presume that the effect of the proposal, if implemented, would be to 'ban' them.Can I remind everyone that the petition does not call for them to be banned, but to be the correct size for safe use.
My very point.As there are no detailed statistics collected on electrocutions in the home, it is unlikely that it can be statistically proven that socket covers increase or decrease safety ...
'Good engineering practice' would not necessarily guarantee an increase in safety (in relation to shock hazard).... there are some things where statistics are not the best indicator. This needs to be judged from a standpoint of good engineering practice.
You may not have intended to type what you did, since that would be a daft thing for anyone to believe, let alone be able to 'make a case for'.I challenge anyone to make the case that incorrectly sized socket covers are more likely to increase safety than correctly sized socket covers.
I don't think that (m)any people (certainly not me) have 'objected' to the petition.Only if you can make that case can you reasonably object to the petition.
Indeed - which is why, as I've said, I would fully support the introduction of Standards, subsequently backed by legislation, to require that all devices intended to be plugged/pushed into BS 1363 sockets met the same (relevant parts of) the specification as required of plugs.Can I also remind everyone that there is a second risk introduced by the use of incorrectly sized socket covers. ....
I obviously can't "make a case" because, as I've said, and as you've agreed, adequate statistics on which to base such a case don't exist. However, even though I'm certainly not happy with 'incorrectly sized anything' being plugged into a socket, it's certainly not impossible that "incorrectly sized socket covers which damage contacts or shutters" have resulted in a net decrease in injuries/deaths (compared with the situation with no covers) ....I challenge anyone to make the case that incorrectly sized socket covers which damage contacts or shutters are a good thing.
True, but that's not quite what we were discussing. Yes, there are plenty of examples of things that were well-established, and not illegal, for very long periods of time before they were banned (primarily because those were times when nothing was banned) - but that doesn't alter the fact that, as we were discussing, if any of them (or many other things, like alcohol and tobacco) were to appear for the first time in 2012, they would be 'instantly banned', without waiting for them to be used for a few centuries first!Sorry, going off topic but :Most "recreational" drugs had been "discovered" for centuries before they were banned i.e cocaine, opium, cannabis et al. and were in general use. Opium was taken quite openly in London before being banned. Cannabis was commonly brought from local shops etc.Alcohol and tobacco are no-brainers. If either had appeared in recent times, they would undoubtedly have been banned, and quite probably classified as "Class A" drugs.What if alcohol had just been discovered?
Very probably, unless they adapted the tests. Such testing usually seeks to detect very small hazards and hence involves dosing animals with amounts vastly in excess of those intended for human consumption. If that was done with salt, no mammal would survive.AFAIK, if tested for safety as a food additive, salt would be banned.
Probably, and undoubtedly countless other things. Nor is it only food additives - things like chillies and suchlike could be high on the hit list, since they are a very significant risk factor for the development of mouth/thoat (and probably some other) cancers.Could we add caffeine to the list of alcohol and tobacco?
That statement is wrong. Good engineering practice would dictate that socket covers (if they are to be used) be made to the size which has been determined as safe for a plug. A socket cover should fully cover the pin apertures of the socket, in accordance with the dimensions specified in BS 1363-1, rather than leave the aperture partially exposed. (After all, preventing access to live parts is what the socket covers claim to do.) A socket cover should also meet the dimensional specifications for the size and disposition of pins, this ensures that it does not cause any damage to contacts and/or shutters, or (in the case of overly long pins) burst through the back of the socket. Correct pin dimensions also ensure that a socket cover will be held as securely as safely possible in the socket, and not be partially ejected by the socket contacts operating to squeeze out pins which do not maintain the correct profile for a sufficient length. Having pins of the correct length also reduces the ease with which the socket cover can be inserted upside down.'Good engineering practice' would not necessarily guarantee an increase in safety (in relation to shock hazard).
I would like to make it absolutely plain that what I typed is exactly what I intended to type.You may not have intended to type what you did, since that would be a daft thing for anyone to believe, let alone be able to 'make a case for'.I challenge anyone to make the case that incorrectly sized socket covers are more likely to increase safety than correctly sized socket covers.
