Confused now??
Have to say this exercise is pure basic as it gets
Reading this post has been likes trip to the dentist, painful
Confused now??
Dropping the pressure, re-charging the vessel would take a pro 10 minsCertainly no draining down...
Yep it sure would if the boiler had a drain point that was not on the DHW out....
I drained it anyway via this method BUT the boiler and in the end disconnected the Pressure Gauge which on the DHW in and connects to the EV.
So all sorted anyway.
Cheers
Bilabonic, I take it you are not serious, you are pulling a leg with your post above, right?
Pressure gauge on DHW side?
Been doing this task for last 25 years, yet to read such a profound clear
Have several customers with this boiler, yet to do an EV fix as you have detailed
A bit of free advice, look at the schematic diagram for optima 701, you might get better understanding of boiler components
How did you fix the erroneous reading pressure gauge
Very few boilers have drain points...there are other ways.
Exactly...drop the pressure with the PRV..., re-charge the vessel, stick a new AAV on, whip off the PRV head and clean the seat...job done.
Always learning...I'm currently trying to get to grips with C++ and Atmel timer interrupts...now that's a challange that makes you scratch your head![]()
So now you are telling us that you actually installed the boiler but still tried to drain it from the DHW outlet![]()
