- Joined
- 20 Oct 2020
- Messages
- 1
- Reaction score
- 0
- Country
I have fitted a shower cubicle over a tray.
All walls are covered with mermaid shower panels.
1 wall is a stud wall.
1 wall is (I believe) breeze block, but with a insulated plaster board dot and dabbed on front.
1 wall is standard plasterboard on what I now know is thermalite. I had intended to mount a fold down shower seat on this wall, but the plumber has advised against it.
He has also advised against using the other solid wall due to the insulated plasterboard (I guess there would be an inch where the screws were not in a solid wall).
Is that correct?
Would a seat which folds down with legs that rest in the tray be ok? If so which wall would it be best on? What type of fixings should I use?
As it stands I have access to the rear of the stud wall - although I suspect this is a non-starter.
For information, the seat would be needed to hold up to 25 stone.
Any help or advice gratefully received.
Is that correct?
