As I moved all my services under the stair, I thought would be good to closed it down and have access with double door opening. This will allow to push is the washing machine as well and have access for boiler and cylinder maintenance.
My idea is to frame off and board on both side having it flush with the stair string.
I was thinking to use some 38x63mm studwall for the frame but not sure if there is any door available or these would be bespoke. ( Cheap option would be ideally)
The 2 doors will need to be cut at the same stair angle to maximise height.
Because I don not have experience on it. Would some of you give me some tips on how to start and what I will need to buy.
Much appreciated.
Much appreciated.
