    Dismiss Notice
gas fire installation
Discussion in 'Plumbing and Central Heating' started by recoverydude, 14 Feb 2019 at 9:18 AM.
  1. recoverydude
    recoverydude
    Thursday
    4
    Thanks Received:
    Country:
    Hi All
    I've had a quotes to put in a gas pipe from the meter to the chimney and install fire.
    The pipe is 4 meters straight line under floorboards ,which are removed
    Fire £530 inset.
    Two quotes £2000 and £1300 and told 4 hours work,including VAT.
    Seems to be a big difference and a bit expensive.
  2. Gasguru
    Gasguru
    9 Sep 2005
    9,363
    Thanks Received:
    2,140
    Sussex
    Country:
    Is the fire included in that price?
  3. durhamplumber
    durhamplumber
    23 May 2010
    3,524
    Thanks Received:
    169
    Durham
    Country:
    4hours work,, he/she aint messing about
  4. durhamplumber
    durhamplumber
    23 May 2010
    3,524
    Thanks Received:
    169
    Durham
    Country:
    That must inc fire,,,otherwise you been taken rit up from behind.Even then,,£1300 inc vat for 4hours work is quite exp,if only 1 person involved
  5. Hot&Cold
    Hot&Cold
    16 Jun 2017
    1,414
    Thanks Received:
    242
    Country:
    during their estimating visit to your property,what was actually discussed and are you happy at how they want to go about the installation ?
  6. ianmcd
    ianmcd
    15 Aug 2010
    8,817
    Thanks Received:
    2,364
    Lanarkshire
    Country:
    we cant quote online, you have had two companies in who have actually seen what is required, we dont have a clue what is involved
  7. durhamplumber
    durhamplumber
    23 May 2010
    3,524
    Thanks Received:
    169
    Durham
    Country:
    Cannot be that much involved,,running a gas pipe and fitting a fire in 4 hours
  8. ianmcd
    ianmcd
    15 Aug 2010
    8,817
    Thanks Received:
    2,364
    Lanarkshire
    Country:
    well some claim that they can change a boiler in 4 hours where I take 2 days, as I fit and flush correctly, if you are so good that you can price a job without seeing it I am surprised you have time to be on here , you must be rushed off your feet
  9. FiremanT
    FiremanT
    16 Jan 2012
    7,027
    Thanks Received:
    1,224
    Uk
    Country:
    I am with you on the 2 days, Ian, but the OP is saying, I think, that the installers said t was 4 hours.
    TBF, if the chimney opening is fully prepared, and the fire is run off the mill, I could do it well insde 4 hours, given that the boards are already up. Although I would not neccessarily promise that to a client, and, if I was asked how long have I quoted for, I would say that I will do it without diving off to other jobs, the whole day is available, but I do not expect to use it all. Experienced guys will understand why I take that stance.
    OP: Even the lower one seems as much as you could possibly charge, but depends on a lot of things - accessibility of site/parking and locality to name only 2.
    If you are uncomfortable with the price, get another quote: BUT, make sure the installer is properly experienced in fires, and is certified by gas safe:
    Find or check a Gas Safe registered business - Find or check a Gas Safe registered engineer in your area who can fit, fix and service your gas appliances.
    • Thanks Thanks x 1
  10. SammyInnit
    SammyInnit
    1 Feb 2012
    2,161
    Thanks Received:
    214
    Wolverhampton
    Country:
    Holy See (vatican City State)
    What area does OP live in?
  11. ianmcd
    ianmcd
    15 Aug 2010
    8,817
    Thanks Received:
    2,364
    Lanarkshire
    Country:
    Totally agree @FiremanT I just have a gripe about anyone challenging a price that has been given by an attending engineer who has actually seen a job and given a quote, yes the quotes seem high but we havent seen the job , the ones who have quoted have seen the job, 4 hours with floorboards already up for 4m of pipe and fit a fire ????? I smell shoite
    • Like Like x 2
  12. MrBenchmark
    MrBenchmark
    25 Jan 2007
    1,164
    Thanks Received:
    145
    London
    Country:
    This presumption that you just fit a fire and leave is great.
    The flue integrity needs to be checked..chimmney may need sweeping. If lined may need a new liner. That may need a scaffold to be done safely and correctly.
    However, there are plenty of fire installers you see with just a long ladder trying to thread a 5 mtr liner down.
    Christ we havent even taken the fire out the box yet!!
    Then we have ventilation..depending on size of fire normally discounted under 6.9kw.
    However i have seen some 14KW gas fires of late.
    Then we got to pipe up the gas...that could be a pig if its an existing fireplace that has no provision for getting pipe from a-b.
    You can no see why so many RGIs drop fires from there elements. In general its become the preserve of the fireplace shops and woodburner installers who tend to charge the earth because they can.
  13. FiremanT
    FiremanT
    16 Jan 2012
    7,027
    Thanks Received:
    1,224
    Uk
    Country:
    The presumption on which comments are based is that the OP indicated the quoting guys suggested 4 hours.
    BTW, 5 metres?
  14. gas112
    gas112
    27 Oct 2009
    15,799
    Thanks Received:
    4,376
    Country:
    5 metres must be a bungalow firemant ;)
    nothing up with working off a ladder threading the usual 9 metre length of copex down it was a standard day to day job .
    Why are so many meant to be proffesional tradesmen scared of fires they are a bog standard appliance .
    Think the OP needs to give a bit more info of what is to be done
    • Like Like x 1
  15. FiremanT
    FiremanT
    16 Jan 2012
    7,027
    Thanks Received:
    1,224
    Uk
    Country:
    Scaffolding for a standard glue liner job?
    In the day there probably would not have been enough scaff to go around.
    • Like Like x 2
Loading...
Share This Page
