- Joined
- 7 Oct 2006
- Messages
- 9,701
- Reaction score
- 4,646
- Country
At work yesterday installing a ravenheat csi 85t combi (i was changing the rad valves) the (older) gasfitter could'nt get to the 22mm gas pipe (on the other side of a dwarf wall) but could see it. Now on these boilers you are allowed 3m including bends etc of 15mm gas pipe to the boiler so he connected a 15mm to 22mm reducer to the exsisting gas main (leaving approx 2 feet of 15mm) then proceeded to take 22mm to approx 4 inches away from the boiler. When commisioning all was fine with the gas pressures (inlet pressure 20mb burner pressure 10.5 mb). I would have thought this was wrong(and told him) but he just said as long as the pressures are ok it does'nt matter. What do you guys think of that then
