GU10 Bulb Replacement
17 Mar 2006
Hi, sorry the stupid question but how do I replace a GU10 halogen spot bulb fitted in my ceiling? I just can't get it out of the ceiling!
Twist it. May need upward pressure (against the lens) if you can't get to the sides.
with ours there is a kinda horseshoe shaped metal ring that goes most of the way round the edge of the bulb, at the ends there are little clips you pinch, then bulb just drops down and you can hold the fitting and twist the bulb out.
Thank you!!!! you can't imagine how happy I am! 2 weeks of trying...
thats not a GU10. Thats extra low voltage . . . . :roll:
apologies - you say "twist the bulb out" - this would indicate it is in fact GU10. But I never heard of a GU10 fitting with a retaining ring - most have a fixed lampholder and you just twist the bulb out by applying pressure to the lens.
We had a set of ELV which had a "flying" lampholder and retaining ring, which you describe, so the lamp drops down, which is why i automatically thought ELV.
Would be good to see this more on GU10 fittings - makes them easier to change, certainly!
I've had the same problem with the GU10 bulb getting stuck. (its a pain as some bulbs do just drop down, while some just stay there)
The clips are taken off and I've tried to twist the bulb but its stuck so fast it won't budge.
I asked the guy at B&Q to suggest something and he reckoned the sucker arrows that kids play with!
Can't find one of those but if anyone has any other suggestions I'd be eterernally grateful.
smash through the front glass of the bulb and turn with pliers?
yeah and if that breaks do some more smashing to get something to grip
all with the power off ofc.
