Guess the fault 2
12 Jan 2008
Essex
Dimmer pack less that 2 metres from Dist board.
Twin and Earth Cable run behind hollow wood panel
Colours connected right both ends but dimmer reverse polarity on the supply terminals.
This was in a major chain pub so would assume dimmer packs fitted by somone competent.
Nail / screw through the cable causing a L-E short on a non-RCD protected TT system?
And why would someone go to the effort of crimping a joint in there, when the entire cable is only 2 metres long?
