I am fitting heated towel rail into my new bathroom. Obviously I will be getting the correct building regulations and ensuring it and everything else is correctly bonded out.
The cable from the heater element is quite short, maybe about 2 feet long. I would like to fit the switch to activate the heater outside the bathroom. However the heater is on the opposite wall from the door so the only way to get the heater cable to the switch is to extended it and run the cable under the floor.
Obviously this means using a junction box. Is it acceptable to fit a junction box under the bathroom floor? What if water leaks through the floor into it?
Should I run the flex from the heater through a wall mounted cable exit under the floor to a junction box. Then run suitable t&e cable to the switch on the outside wall where i also make the mains connection?
Or should I run the switch to the junction box and the mains to the junction box and wire it in a similar fashion to a light...
