Thank you - I will be asking someone else to do the task but not many people understand the system as its complicated
I had people suggest an unvented cylinder! And also a combi boiler so I want to make sure I know what to ask them to do
The 2 port valve was always there even before the cylinder was changed and worked fine. The cylinder was replaced and the pipework bent upwards and in 22mm rather than 28mm
If I follow the very helpful advice here I am told
For me its most important to get the cylinder working from gas again and it looks like the concensus is to put pump either after the two port valve or instead of it yes? Failling that a gravity coiled cylinder
- Not worth trying to do the boiler flow in 28mm and rebend it so gravity will push water through coil - Absolutely no point in trying that?
- Add a pump after the two port valve (Problem is what happens when 65 degrees thermostat on cylinder is met and how it can be turned off if I remove the port valve
- I don’t completely understand your point on hot water rising in the radiator - Some of the radiators are cold at bottom but I put that down to sludge
