How I Rewired the Shed
3 Sep 2006
Kent
The Old wiring in the shed
The way the shed was wired up was a 16amp MCB to 2.5mm T+E to Metal app box to 2.5mm SWA going through the wall of the house, then along the ground, into the shed, along the shed floor at the back of the shed, along the shed floor at the side of the shed, and into a Wylex Standard 4 way metal ccu.
From the shed ccu:
Circuit 1 = one double socket in the shed (15amp Rewireable fuse)
Circuit 2 = four outside sockets on side of shed (15amp HRC fuse)
Circuit 3 = Lighting (2 Gang light switch, which runs: First Gang= Shed light. Second Gang= Floodlight on back of house to light up the garden) (5amp Rewireable fuse)
Circuit 4 = Spare
Here are some pictures of the old wiring in the shed
House end of old shed supply:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00015.jpg
Old outside sockets on next door's side of shed:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00030.jpg
Old shed light switch:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00031.jpg
Old light wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00034.jpg
Close up of old light switch wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00036.jpg
Old Shed light:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00035.jpg
Close up of old light wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00078.jpg
Old Socket:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00037.jpg
Old Shed CCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00038.jpg
Old CCU Fuse Cover:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00039.jpg
Old CCU with Fuse Cover removed:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00040.jpg
Old CCU with Fuses removed:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00041.jpg
Old CCU with main cover removed:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00042.jpg
Old CCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00044.jpg
New Method of Earthing SWA
http://i167.photobucket.com/albums/u125/mdbalson/DSC00045.jpg
Old CCU Wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00046.jpg
And notice that:
1) No Grommets on CCU
2) SWA not earthed propatly at the shed ccu end
3) wires in ccu not in the terminals propatly
4) Wrong Fuse backing on the lighting slot (30A Back instead of 5A one)
scousespark said:
why have you posted this? isn't this in your earlier thread?
I am making this post to put in all of the pictures of how I rewired the shed, as people are saying that the other post about the shed is too long at 7 pages.
The way I have rewired the shed is:
I put the shed on the Non-RCD CCU, for now & I am going to then move it over to the non-RCD side of the New 17 way Wylex split-load board am going to put in soon, to replace the old 6way MEM CCU & the old 4 way RCD Contactum CCU with.
The shed is on a 30 amp MCB, in the House ccu (the MEM one)
6mm T+E, which runs from the ccu up the wall to the outside JB, where it connects to 6mm 3 core SWA, which runs to the Shed CCU
New Shed CCU is a Metal Wylex 5 way Consumer Unit with a 100amp 30mA RCD mains switch.
Put in three Metalclad DP double sockets along the worktop, & a Metalclad switched FCU for the 2kW Heater, which will be on a Ring Main, on a 32amp MCB in the shed ccu (Plug the Tumble Dryer into one of these sockets),
Have the pond pump, an outside socket, the LV Garden lights (x2), the light in the summer house, and the pond lights as a Ring circuit on 32 amp MCB in the shed ccu.
Put the shed light, & the outside shed light (the light above the shed door) on a 6 amp MCB in the shed ccu.
Run the Cables in the Shed in Round 20mm PVC Conduit.
Clip up the 6mm SWA with cable cleats
Put in a 12 Gang Metalclad MK Grid System with :
The Shed Light (a 5ft Tube) on a 10Amp 2 Way SP Switch
The Outside Shed Light on a 10Amp 2Way SP Switch
The summer house light (a 3 or 4 ft Tube) & a socket on a 20Amp DP Switch & a fuse holder with a 13 amp fuse in. (I will put a fcu in the summer house to fuse down to 3amps for the light)
The 6 LV Post lights (Top of Garden) on a 20Amp DP Switch & a fuse holder with a 3 amp fuse in.
The Side Path LV lights on a 20Amp DP Switch & a fuse holder with a 3 amp fuse in.
The Pond Pump on a 20Amp DP Switch & a fuse holder with a 3 amp fuse in.
The Pond Lights on a 20Amp DP Switch & a fuse holder with a 3 amp fuse in.
(2 MCBs fed the grid switch)
The Outside Shed Light will be a photocell controlled light
Click link for picture of light http://www.tlc-direct.co.uk/Products/GLFIN255.html
To fed the two sets of LV Garden lights, and the pond pump and the summer house light & socket, I was going to use two lengths of 4 core 2.5mm SWA, to power them.
One length will be to power the pond pump, and the 6 LV Post Lights. (By using two of the 4 cores for each thing = Two sets of Live & Neutral cores, and use the Steel Armor as the Earth.)
The Other length would be to power the Side Path LV Lights, and the summer house light & socket. (By using two of the 4 cores for each thing = Two sets of Live & Neutral cores, and use the Steel Armor as the Earth.)
The Run of the shed SWA is about 13m from the outside JB on the house to the shed ccu.
New Shed CCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00050.jpg
2 New Sockets:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00051.jpg
1 New socket & FCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00059.jpg
New Shed CCU with shed ring wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00062.jpg
2 New Sockets with wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00061.jpg
1 New socket & FCU with wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00060.jpg
110V Flood Work Light:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00053.jpg
110V 25m Ext. Cable:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00054.jpg
http://i167.photobucket.com/albums/u125/mdbalson/DSC00055.jpg
http://i167.photobucket.com/albums/u125/mdbalson/DSC00057.jpg
http://i167.photobucket.com/albums/u125/mdbalson/DSC00056.jpg
110V Transformer:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00058.jpg
Close up of Socket wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00065.jpg
Close up of Heater FCU wiring (there is no heater connect to it yet, as I have not bought it yet):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00070.jpg
1st New socket:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00066.jpg
2nd New socket:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00068.jpg
New FCU for Heater:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00076.jpg
New SWA with Gland on:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00071.jpg
New SWA going into Shed CCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00072.jpg
Close up of shed CCU, showing earthing tag on the SWA:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00075.jpg
Shed CCU with innerds in:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00074.jpg
The New SWA Feed to the shed:
The 3 waterproof JBs on the outside of the house (1st one is for the shed freezer circuit, 2nd one is for the shed circuit, & 3rd one is for: 1) the immersion heater circuit 2) the loft radial circuit):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00155.jpg
Shed JB (view 1):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00157.jpg
Shed JB (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00159.jpg
Shed JB (view 3)
http://i167.photobucket.com/albums/u125/mdbalson/DSC00160.jpg
Close up of wiring in shed JB:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00161.jpg
Shed Freezer SWA:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00162.jpg
Shed SWA:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00163.jpg
Both SWAs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00164.jpg
Shed SWA going into JB:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00165.jpg
SWA coming into shed from outside:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00129.jpg
SWA:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00128.jpg
SWA going around corner of shed:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00127.jpg
The Cable Chase in the kitchen:
The Cable Chase:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00150.jpg
The top of the Chase:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00151.jpg
The Chase with cables clipped up:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00152.jpg
The bottom of the Chase:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00153.jpg
The chase was done using a chasing bit in my 110 SDS plus hammer dill
The Grid Switch & more Conduit runs:
Lighting & Outside power conduit:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00133.jpg
Lighting & Outside power conduit (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00132.jpg
Grid switch Back box & conduit runs to it:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00130.jpg
Grid switch Back box & conduit runs to it (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00131.jpg
25mm conduit run to the 2 outside JBs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00166.jpg
25mm conduit run to the 2 outside JBs (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00167.jpg
The 2 outside JBs for the 4 core SWA to connect to:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00168.jpg
The wiring to the Grid Switch:
Grid switch wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00137.jpg
Earth to Grid switch back box:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00139.jpg
Wires to fed the 2 outside JBs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00170.jpg
25mm bend with wires in:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00171.jpg
25mm tee & bend with wires in:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00172.jpg
Close up of 1st Grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00174.jpg
Close up of 1st Grid wiring (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00175.jpg
1st Grid in place:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00176.jpg
Wires to outside JBs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00179.jpg
Close up of 2nd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00177.jpg
Close up 3rd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00178.jpg
Close up of 2nd & 3rd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00180.jpg
Wires to 5 amp round pin socket (for pond lights):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00182.jpg
Close up of round pin wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00184.jpg
The finished 5 amp round pin socket:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00187.jpg
All 3 grids in place:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00183.jpg
The finished grid switch:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00188.jpg
The Light wiring:
Outside light wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00135.jpg
Shed light wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00134.jpg
Shed Fluro Terminal Block:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00189.jpg
Wires in Fluro:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00191.jpg
Wires in Fluro (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00192.jpg
5ft Fluro:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00194.jpg
Outside Light Terminal Block:
Will post up later
Finished Outside Light:
Will post up later
The Outside Socket Wiring
Close up of the wiring:
Will post up later
The finished GET 2 Gang Waterproof Socket:
Will post up later
The CCU Wiring
The CCU with all the Earths & Neturals connected:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00144.jpg
The CCU with all the wires connected:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00146.jpg
The CCU with live busbar cover on:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00149.jpg
The CCU with the cover on it:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00148.jpg
Close up of the MCBs in the CCU:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00147.jpg
Please do not ever buy a block of flats. :P
Every saga has to have an end - doesn't it!!
Spark123 said:
:lol:
Did you miss with some of the SWA strands? They should all be in the clamp, some of them look like they have gone up the inside of the gland. Is it the correct size gland for the cable
All of the SWA strands are gripped in the gland, & it is the correct size of gland for the cable ( 20 Gland which is for 3x6mm SWA)
I have to say, it does look neat.
I hate inspection tees/elbows though - you loose marks for those. Should have used circular boxes :wink: I prefer to see pulled bends where possible.
The insulated enclosured on the house wall look poor IMO - Just not very neat and tidy.
The T+E also enters the rear of the enclosure, and is sealed with mastic - not ideal.
Cleats too large on the 'freezer swa'??
Conduit entry into the top of an IP rated enclosure? I hope you drilled a drain hole? I would always try to avoid entering the top with conduit/swa/trs etc.
Is the chase in a 'safe' zone?
Cable ties would be better inside the grid switch if you REALLY feel you need to group cables.
Tape on the earths and neutrals in CU is cack. It is not needed.
Is the banjo on the CU swa nut and bolted through the case? lookes like you have bolted the cable to the banjo, and then put it into the CU?? How can you tighten if it ever becomes slack? How can anyone check it is tight?
Pulled bend out of top of CU looks good - well formed. Bet that took practice and few lost lengths :wink:
Male conduit adaptor in bottom of grid sw back box - A female would have better suited.
Do you have a new digi-camera-toy or something :lol:
Be careful - Photobucket will start charging you soon :D
There is also the rubber seal of the box, around the T+E.
Yes. :oops:
I think it is as you can see the cable coming out of the chase in the meter cupboard, & also the cables will be covered with steel capping, before the chase is plastered over.
Yes I know it would be, but B&Q ownly do 25mm conduit adaptors in male.
No just my new Sony Ericsson K750i Phone with camera
