One of them WISKA Shark joints will suit you, sir!
Why would it need to be MF? It's a joint in a flexible cable.Does the gel make that choc-bloc maintenance free then?
I thought IP68 was suitable for permanent submersionThey're not perfect, there is no perfect solution if the whole cable can't be replaced, but they are adequate provided you ensure the joint doesn't end up lying in a puddle for a long period. If that occurs, the joint will eventually suck in water as the air pressure inside it changes with temperature.
The connection will be outdoors, but not under water.
Keep a bucket of water nearby just in case.I don't want to set my pond on fire...
Protect the carp?
