    Dismiss Notice
I can't find the fuse for the heating system
Discussion in 'Electrics UK' started by zug, 23 Oct 2017.
  1. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    Hello.
    I have a combi boiler in a Y plan system. I have an airing cupboard with the pump and valve upstairs and the boiler, controller and thermostat downstairs. I believe all of the electrics go into the junction box upstairs which then feeds the valve, pump, boiler and controller downstairs.
    However, there is no electric to any of those components. I have checked the mains feed coming into the junction box and it's dead.
    So I thought this would be a fuse that has blown. I have read that these systems are usually fed from a 3Amp spur. However, I cannot find the fuse anywhere. The RCD hasn't tripped, there is no isolated feed from the RCD to the heating system - only the Water heater which works fine. Every socket in the house still works.
    So I am at a loss. Should I expect to see a fuse box somewhere for the heating system? Is it likely to be near the airing cupboard or the boiler/controller?
    I have looked everywhere but cannot find it.
    Thanks!
  2. Sponsored Links
  3. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    It'll be somewhere.
    It's likely to be wherever the idiot who thought the right thing do do was to hide it hid it.
    You'll just need to follow the supply cable back....
  4. JM2
    JM2
    14 Nov 2010
    174
    Thanks Received:
    10
    Retired in:- Nottinghamshire
    Country:
    Depending upon age, often the main feed is via a fused spur to the boiler or boiler's timer/programmer.
    The fused spur or switched spur is what is hidden but if you have a flex from the boiler itself or the programmer you can follow that.
    - The Y plan kit elsewhere is often fed from the programmer.
  5. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,456
    Thanks Received:
    2,116
    Oxfordshire
    Country:
    As above. It should be near the boiler or the wiring centre..
    • Thanks Thanks x 1
  6. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    I can see the mains coming into the back of the programmer which I think is then going onto the boiler and upstairs to the cupboard.
    However I checked the mains input with a multimeter and there is nothing. No sign of a fuse near by either. I've called an electrician to come and have a look.
  7. stem
    stem
    20 Jul 2005
    6,621
    Thanks Received:
    1,538
    Nottinghamshire
    Country:
    You should be looking for something similar to this?:
    The location of it depends upon the preference of the installer, but normally as has been said it is located near to the boiler so that it can easily be switched off when it's serviced, or near the wiring centre which is usually the airing cupboard (occasionally it is connected to the one for any immersion heater) or it may be next to the programmer.
    Has the boiler been moved or replaced at some point? if so the original FCU might have been used.
    If it's in the kitchen has this been altered? I found one once behind a wall mounted cupboard.
  8. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    Yes, that's exactly what I'm looking for. I can't find it anywhere.
  9. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    Nevermind - I have just found it. Can't believe I didn't see it all along.
  10. Sponsored Links
  11. footprints
    footprints
    21 Sep 2011
    4,466
    Thanks Received:
    957
    Country:
    If it is a combi chances are it is a replacement, I bet the isolation is in the same position as the original boiler was sited.
    Where was it then?
  12. winston1
    winston1
    11 Jan 2010
    6,986
    Thanks Received:
    531
    London
    Country:
    Good, if a 3 amp fuse has blown, it probably because it should have a 5 amp. Don't worry about causing any damage, the boiler will be internally protected. Don't go above 5 amp though. Elsewhere in Europe boilers are on 16 amp circuits and there no reports of fires or electrocutions.
  13. JohnW2
    JohnW2
    28 Jan 2011
    48,180
    Thanks Received:
    3,149
    Buckinghamshire
    Country:
    You're quite probably right (about electrocutions and fires not being due to boilers being on 16A circuits) but, as a matter of interest, where did you get your information on "fires and electrocutions in the EU"? If the rest of the EU is anything like the UK, getting useful data on such matters, other than crude totals of electrocutions and of fires which the Fire Service, maybe through lack of better ideas, deem to be 'electrical', is next-to-impossible.
    Kind Regards, John
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,099
    Thanks Received:
    4,164
    Retired to:
    Country:
    Portugal
    I know it isn't what you wrote - but the implication, if what Winston wrote is not true, is that they just put up with fires, injuries and deaths for the want of an FCU?
  15. stillp
    stillp
    21 Sep 2009
    4,496
    Thanks Received:
    338
    West Midlands
    Country:
    Or, as in my house, both. That took some working out!:eek::rolleyes::mad:
  16. JohnW2
    JohnW2
    28 Jan 2011
    48,180
    Thanks Received:
    3,149
    Buckinghamshire
    Country:
    I suppose that would probably be the implication. There are certainly national differences - for example, in the US they seem to 'put up' with numbers of deaths due to a number of causes which I doubt we would find acceptable in the UK.
    However, I was giving Winston the benefit of the doubt and assuming that he was telling the truth. I've spent a lot of time and effort looking for decent detailed statistics on injuries, deaths and fires due to electricity and have failed fairly miserably. I therefore wondered whether Winston had located a 'secret' source of such data that I had so far not been able to find.
    Kind Regards, John
  17. stillp
    stillp
    21 Sep 2009
    4,496
    Thanks Received:
    338
    West Midlands
    Country:
    There are, or were, some on Eurostat, but I can't find them now since they reorganised the EU web site.
    • Thanks Thanks x 1
Loading...
Share This Page
