I have to intall a spur from a ring main i will be coming from a surface mounted double socket along an inside wall approx 6 metres using 20mm plastic pvc conduit.
1. what distance do the sadles need to be apart?
2. the excisting wiring is in the old colours RED, BLACK AND YELLOW/GREEN, could i use the same colours to install spur, or do i need to use new colours?
3. testing, i believe a minor works paper needs to be filled, what tests would i need to do?
4. the excisting wiring is in 4mm could i come off with 2.5mm or do i need to use 4mm (socket only being used for office equipment)
