I wasn't sure if this should go in this forum or in the electrical forum but hoping this is the right place.
I've got an OSO Direct 20 RD unvented water heater (210 ltrs nominal storage at 2 bars).
This is in a 2 bed flat, electricity only.
From reading around and looking at the manual I understand it has 2 immersion heaters. Both of which are wired to two physical switches on the adjacent wall.
I know nothing about these things so forgive any stupid questions, but my understanding/assumptions are that the heaters are permanently receiving power and supplying current to the elements when the internal thermostats drops beneath the temperature set by the adjustment screw (60°C for both).
This will obviously cost a lot of money, especially in today's energy climate. So i'm looking to reduce my outgoings by installing a programmer/timer (or two, one for each immersion heater?).
I believe the intent behind the two heater design is that the lower is fed with economy 7 electricity at night. I'm not on an economy 7 plan although we do have a smart meter which is compatible. I'd have to switch plans to take advantage of this though and that would involve exit fees and no doubt a higher tariff overall (currently fixed at 18.35p per kWh until Sept '22).
Questions:
Questions:
- Am I incorrect in my assumptions?
- Would a timer help reduce costs?
- What is the difference between a timer and a programmer? Which would be suitable?
- Would I require a separate timer to ensure the lower heater turned on at night and the upper in the morning (assuming some future move to an E7 plan)?
- Are timers simply wired in-line i.e. would I have to cut the cable and wire the timer up in the middle?)
- Can anyone recommend a timer/programmer?
- I understand some timers have a boost function, our shower is non-electric so i'm assuming we'd want this available on whichever timer (assuming two separate units) to the lower immersion heater. Is that correct?
