So lets say for example I have a grind stone plugged in, the weight of the stones will keep it revolving for a little time, and the back EMF can give you a nasty shock if you touch the plug before it has stopped revolving, but likely they will not revolve for too long, so one would need to be quite unlucky to get a shock from the plug, but if that back EMF causes the plug-in solar inverter to think it is still connected, it may extend the time.
Real world testing was done with the prohibition on extension leads following on from that and consultation responses about misuse concerns of extensions and adapters, such as daisy chaining.
That wasn't "them" that make the rules, but some other "thems" who can be as silly as they like.Is that when they discovered the hitherto unknown fact that extension leads are directional?![]()
I once had an 'Consultant Engineer' tell me the microphone infrastructure cables we were running in a theatre had to be run in the same direction when he saw us forming a bunch to pull into containment by tying the 'start' and walking a loop to the length required repeatedly, IE back and forthIs that when they discovered the hitherto unknown fact that extension leads are directional?![]()
With an extension lead with a single socket it would not make a difference, but with multi-sockets it could.How would the use of an extension lead make a difference?
Some of these "theories" by those "in the know" make some of our comments like the same electron gets used each time there and backI once had an 'Consultant Engineer' tell me the microphone infrastructure cables we were running in a theatre had to be run in the same direction when he saw us forming a bunch to pull into containment by tying the 'start' and walking a loop to the length required repeatedly, IE back and forth View attachment 423612rather than pulling the start to the other end, cutting and repeating to double the amount of walking required.
Because it has been a success across Europe and only fair we get the option.Why was plug in solar allowed to start with?
Batteries will come and prices will drop as time goes on.plug-in solar was to help Joe public, then it would have batteries, since batteries not included,
We will likely see other restrictions lifted.Batteries will come and prices will drop as time goes on.
The fact that you can unplug it from the wall socket and ... IF the inverter fails to shut down, then you'll have live pins.How would the use of an extension lead make a difference?
While I'm sure it wasn't the reason they had in mind, there are practical reasons for pulling cables the same way.I once had an 'Consultant Engineer' tell me the microphone infrastructure cables we were running in a theatre had to be run in the same direction when he saw us forming a bunch to pull into containment by tying the 'start' and walking a loop to the length required repeatedly, IE back and forth View attachment 423612rather than pulling the start to the other end, cutting and repeating to double the amount of walking required.
Thinking mic cables & XLR connectors, the lay of the cores (& drain wire) is easier one way than the other - one way you have a crossover, the other way you don't.
Twas to do with misuse concerns, like daisy chaining, raised during the consultation.The fact that you can unplug it from the wall socket and ... IF the inverter fails to shut down, then you'll have live pins.
