My Eco RF 30 has started making a beeping sound, any idea what this could mean?
Cheers.
Cheers.
Definitely the bolier as if I turn off the power it stops, you can also tell it is coming from inside the casing anyway.Are you sure it's the boiler and not something else nearby? As far as I'm aware, there isn't anything on the boiler which can make that kind of noise. @Razor900 ?
It was doing it on mode 4 and 5 it just happened to be switching off when I took the video (it’s controlled via a Nest via Opentherm)How odd. I've tagged Razor because he's a senior Intergas tech, so he might have an answer for you. Boiler is showing pump overrun mode so it might be the pump beeping, although I've never heard it do that on any of the ones I've fitted.
Yes call the office on 01527888000 and get it booked in. The noise is the alarm telling you the pump is starting to seize and it will stop completely in the near future.
No need to worry - the boilers are extremely reliable, and we don't yet know that it's a boiler fault anyway - could be some installation debris or dirty system water that's blocked it up. It's the only boiler that will give you hot water with a stuck pump!I only had the boiler fitted in April this year and it’s had very little use so far so I’m now worried I’ve made the wrong choice for reliability. At least I’ll still have hot water whilst I wait for it to be fixed though.
You'll probably get a visit from Alan, make him a cuppa and talk about motorbikes and he will be your friend forever!!
And at least with the Intergas you can still have hot water
