    Dismiss Notice
Is it necessary to change a 23 yo fuse box?
Discussion in 'Electrics UK' started by FiremanT, 19 Jun 2021.
  1. FiremanT
    FiremanT
    16 Jan 2012
    9,085
    Thanks Received:
    1,780
    Uk
    Country:
    The electrician said that any 23 year old CU is due for replacement.l
    Thanks for any comments
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    36,836
    Thanks Received:
    4,123
    Retired to:
    Country:
    Portugal
    It depends.
    • Like Like x 2
  4. EFLImpudence
    EFLImpudence
    7 Jul 2010
    36,836
    Thanks Received:
    4,123
    Retired to:
    Country:
    Portugal
    To be more helpful, if it were in my property and it is in good order then I wouldn't bother.
    However, if the property is to be let then you will be advised to bring it up to the latest modern standards as it is generally thought that tenants must have every modern safety device available because - well, just because.
    • Like Like x 1
  5. securespark
    securespark
    11 Jan 2004
    36,783
    Thanks Received:
    1,261
    Country:
    Because they're worth it
  6. JohnW2
    JohnW2
    28 Jan 2011
    47,851
    Thanks Received:
    3,118
    Buckinghamshire
    Country:
    Who/what is 'worth it' - the tenants, or 'every possible modern safety device' (or both!!) ?
    Kind Regards, John
  7. flameport
    flameport
    10 Mar 2007
    9,731
    Thanks Received:
    1,931
    Poole, Dorset
    Country:
    That consumer unit is old, and certainly would be beneficial to replace it.
    However replacement is not necessary for the addition of a double socket to one of the existing circuits.
  8. FiremanT
    FiremanT
    16 Jan 2012
    9,085
    Thanks Received:
    1,780
    Uk
    Country:
    Thanks.
    In what respect would it be "beneficial"? Is it £550 worth of beneficial?
    • Like Like x 1
  9. Notch7
    Notch7
    15 Sep 2017
    24,348
    Thanks Received:
    1,737
    S. Uplands
    Country:
    Should I replace my consumer unit, it was installed in 1959.
  10. Sponsored Links
  11. securespark
    securespark
    11 Jan 2004
    36,783
    Thanks Received:
    1,261
    Country:
    Yes!
    And the rest!
  12. JohnW2
    JohnW2
    28 Jan 2011
    47,851
    Thanks Received:
    3,118
    Buckinghamshire
    Country:
    I somehow dioubt that it is a "Consumer Unit", by any definition of which I am aware :)
    In 1959, the house I was in did not even have anything which one could really call a 'fuse box' - just a couple of cast iron switch-fuses ('re-wireable', of course)!
    Kind Regards, John
  13. securespark
    securespark
    11 Jan 2004
    36,783
    Thanks Received:
    1,261
    Country:
    The brown Wylex fuseboxes made their debut a few years before.
  14. JohnW2
    JohnW2
    28 Jan 2011
    47,851
    Thanks Received:
    3,118
    Buckinghamshire
    Country:
    Maybe, but I would then have been too young to 'notice' them. I know of the cast iron switch-fuses because it continued to be the case that there was nothing other than them in my parents house (which we moved into in 1956) until well into the 70s :)
    Kind Regards, John
  15. ericmark
    ericmark
    27 Jan 2008
    18,106
    Thanks Received:
    1,686
    Llanfair Caereinion, Nr Welshpool
    Country:
    My parents house 1954 had a 4 fuse Wylex unit. As did my house 1978. Not sure when the Consumer unit arrived? I think in the 90's, a CU is a type tested distribution unit. Personally I want RCD protection so would change it, but unless you alter the bathroom bonding there is not requirement to up grade.
  16. securespark
    securespark
    11 Jan 2004
    36,783
    Thanks Received:
    1,261
    Country:
    I'll try and do some more research into the Wylex fuseboxes.
    I was told by the technical guy Ian Kenworthy at Wylex in the 90s that the Standard fusebox was introduced in 1956 but he may have been a few years out.
  17. JohnW2
    JohnW2
    28 Jan 2011
    47,851
    Thanks Received:
    3,118
    Buckinghamshire
    Country:
    Thanks. That's all quite possible. It was well into the 60s before I first saw anything that we would recognise as a 'fusebox', and I imagine that the first ones I saw would have been Wylex Standards.
    Kind Regards, John
    • Like Like x 1
Loading...
Share This Page
