This where it gets complicated. At some locations the potential difference between CPC and Clean Earth was monitored and if it exceeded a safe limit then alarms were automatically raised.
I don't think I'll go to the extent of having a clean earth running. But I will keep a dedicated circuit - if nothing else it's easy to trip the breaker when going on holiday instead of trying to get behind the cabinet to switch each item off.
The only benefit i can see in having a dedicted circuit is if you supply it via an active rcbo (which requires resetting after power loss)this would protect your speakers from the "hud" on power on if the amp is not switched off, i.e. Quad 504.
