Means that two of the three ports are free. That is all.
Please explain further, which 3 ports?
Think about a tee fitting. Now imagine if one opening is blocked.... How many openings are left?
One is your header tank.... And the other.....?
I thought you were an engineer?
an example of said tee.
This system worked, sporadically for many years in this state.
ChrisW, take it you tested both pipes.
The one with the bleed point will be the flow pipe
Other pipe is the return, might be an idea to check that too
Perhaps you already have
sweat the old soldered joints off then you will have something easier to connect totee would do the job if I cut out the old soldered tee, I
