I've got the wrong wire haven't I?
  • Thread starter Thread starter attractivebrunette
  • Start date Start date
A
attractivebrunette
Am putting up a 12v wire lighting system.
I have a 300 VA toroidal transformer and the track length is about 12 meters with 6 x 35 watt lamps.
However, while the lamps fixed near the transformer are bright, the lamps shine progressively dimmer the further from the transformer they're placed. After about 4 meters the lamps have next to no light coming from them at all.
I think it might be because I've purchased the wrong stainless steel wire? I got the usual 4mm stainless steel cable coated in clear nylon, but I didn't get it from a lighting shop.
What's more, the cable is very warm to the touch, while cables I have for other 12v systems in the house, which were purchased as part of a kit, aren't warm at all.
So, can anyone tell me if there is a special type of stainless steel wire required for 12v lighting systems? Does it need to be a particular impedance or be rated for carrying a particular current or wattage?
:D :D
S'ok, I got the answer. It's the cable that's incorrect. Changing it now :D
What you probably had was wire too thin for the load and distance, hence the reduced light output and raised temperature.
12 metres is a long run @ 12v with that kind of wattage. I'd be surprised if any tension wire you can purchase (that will still fit the lamp terminals) will be big enough.
From that site:
What is the maximum length you can make the wire track?
Five metres is a good length at which to start considering using more than one transformer. On longer runs an isolator can be used so that two each side of a longer run can have up 300 watts of lights. You can use a single transformer for 6-7 metres without being to concerned about voltage drop. Ten metres is possible on 6pm cables but you will see the lamps as brighter closer to the transformer.
