Hi Guys - seeking a bit of advice here about the times it should take to fit the kitchen in the links below
http://www.photobox.co.uk/album/6327682
it consists of a kitchen with
400mm floor
800 mm pan drawer
600mm cooker
500 mm drawers
corner carousel unit
1000mm base
600mm dishwasher
1000mm base
600mm intergrated appliance tower (contains tall larder fridge)
700mm gas hob
1000mm 1.5 bowl and tap
400 wall
600 wall
600 wall
600 wall
1000mm wall
Pelmets
Utility room
500mm tall larder unit
600mm base
2*600 mm wall
300mm wall
now the sink is in the same place and the dishwasher as well in the kitchen, and the sink is in the same place in the utility. I made up the majority of the cabinets (except for the 1000mm and the appliance and larder tower).
All the pelmets are misaligned going from flush with the door front to being proud by about 1cm. The end of one of the pelmets has been scratch coated in where he has filled a cable run. All the pelmets along the front have been screwed into from inside the cabinet and he has over countersunk these holes so it looks unsightly when you open the cupboards. I believe that you should screw into the cabinet from the pelmet (there is a lip at the back to do this)
The door to the dishwasher comes off in your hand - and the handle is not straight by about a cm, plus the door has been chipped by the handle.
We have had the kitchen wall units hung a bit higher than normal which has meant the top of the towers have had to be built up. we asked for the face of this to be in line with the door - he has done 1 and not the other one... and the list goes on!. he took a day to fit the utili...ing. Advice please from people in the know
400mm floor
800 mm pan drawer
600mm cooker
500 mm drawers
1000mm base
600mm dishwasher
1000mm base
700mm gas hob
400 wall
600 wall
600 wall
600 wall
1000mm wall
Pelmets
Utility room
600mm base
2*600 mm wall
300mm wall
