LED lights failing
I suppose it depends upon how one interprets "a short time" and upon when the capacitor was installed (clearly at some time after Monday morning of this week).
Was the switching on the secondary (230 v ) side on on the primary side. ?
Is it a wound transformer or is it an "electronic transformer" ? The fact that a capacitor across the secondary seems to cure the problem strongly suggests that the out put from the "transformer" is not a clean AC 50Hz waveform as would be expected from a inductive transformer.
Simon35's link said:
Kind Regards, John
My error, I missed that.
I suppose that, more correctly, you forgot it ( :) ) - since, soon after Simon posted that, you responded with ...
Care is needed when using transformers with multiple taps on the windings to supply equipment that does not have good ( if any ) filtering on its mains supply. If the end taps are not used then the end portion of the winding is an un-terminated ( unloaded ) auto-tranformer coil....
It remains to speculate about what the capacitor is 'suppressing'.
Kind Regards, John
Yes, switching on secondary side. A wound transformer.
When I spoke to the transformer manufacturer, they said that at the flux densities they design to, there shouldn't be any harmonics generated by the transformer core. Transformer design is not my specialist subject by a long chalk, so I took them at face value.
If you have not done so already (which I presume you probably have, not the lest about warranties!), I would think that there is a very good case for 'having words' with the manufacturer of the LED fittings. It seems definitely wrong that they are producing and selling products which fail very quickly when fed 'in good faith' with the correct voltage from what sounds like a perfectly reasonable/appropriate wire-wound transformer.
Kind Regards, John
Happily for me, I procured the lights and transformer as a package from a single supplier so they have replaced the failed fittings at their cost.
That's good, but I think my point remains - that it would probably be appropriate to talk to the manufacturer about the fact that they appear to be selling lights which die rapidly when fed with the right voltage from what sounds like a perfectly reasonable/appropriate wire-wound transformer. If capacitors are needed in such a situation, should they not be in the lighting units?
Kind Regards, John
Sunray got it in one, control transformers are optimise for control work and shoudnt be used for other purpuses.
Ok. The manufacturer of the transformer was perfectly happy with its use in this application.
I'm not a transformer expert. What would a weld across the lamination do.
