On a project where I have got 8 off 300W LED fittings on a radial circuit from a 400 to 230V transformer.
The fittings are 230V supply, and keep failing either straight away or after a short time, except the one nearest the transformer, which is fine.
The fittings also seem to hum, so maybe a harmonics thing from the transformer?
If I put a plug top on one and plug it into a wall socket, no failure or hum. If I then supply it via the transformer it will fail.
Looking at the failed lights there is some blackening around a varistor on the LED board.
Any thoughts and ideas on the reasons for failure would be welcome.
