- Joined
- 9 Feb 2018
- Messages
- 10
- Reaction score
- 0
- Country
I can’t I’m afraid. It’s not a switch which is used often. I know it worked but I can’t recall if it just controlled one set of spotlights or all of them.
It does. Maybe the person who so often uses that phrase should take note (I only use it when talking about a situation in which he has used it).I would say "Put this wire in that hole" sounds like a demeaning phrase ..."
No, but does not the rest of that post imply that a non-demeaning phrase - wiring diagram - changes the situation?Have you ever heard
So, it appears as if EFLI could have been bang on implying that not all 4 switches were connected up
You seem to be focussing on the question of a wiring diagram, whereas I (and, I believe others) have been talking far more generally about the nature (and 'acceptability') of 'advice' given.No, but does not the rest of that post imply that a non-demeaning phrase - wiring diagram - changes the situation?
I am with Bas on the principle that people who oviously haven't a clue should not be encouraged to continue electrical work.Maybe it's just me, but I'm actually starting to get pretty confused/uncertain as to what side of the apparent disagreements you are on!
