Loose earth bond
To give credit to Watson, he isn't being factually incorrect with those last statements, just misleading.
Since pme, (and before pme too, regardless of pme), it's indeed been regs to bond things that"may become live" (relative to the main earthing terminal, at the point they enter the house)
One that's done, there's not much else that may become live, therefore you're done.
No.
So, not since PME then.
No. That would be earthing and it does not apply to pipes nor sinks.
Bonding is applied to parts which are already earthed so that when they become live because of a fault (until the OPD opens and disconnects the supply) there will be no potential(voltage) between them.
All earthed parts could become live in the event of a fault and remain live if the OPD doesn't work
No.
:LOL:you're not very charitable tonight!
So the cliques collective opinion is that in a steel frame building with steel floors, steel ceilings, metal water and waste pipes a metal sink does not have to be bonded.
Do you think it (the sink in your example) does need bonding?
If so, to what would you bond it, and why?
who (apart from mwatson) can see the words "steel frame building with steel floors, steel ceilings?"
I was replacing my washing machine at the weekend, and noticed one end of the earth bond was tucked behind the back wooden plate under my kitchen sink, not attached to anything.
Can anyone offer any advice as to what I need to do then? ;)
Yes make sure your incoming metallic water supply and gas supplies are bonded directly back to your main earthing terminal.
Ignore any other bonding in your kitchen.
If you don't know how to check, an electrician has the proper equipment to check.
