Hi guys, just after some advice.
Ok, I know that you should always bond the mains water and gas supplies to a property, but what if you have the gas meters for example are in a basement of a block of flats? Then what i would do is bond the gas meters in the basement but also bond the gas pipes where they enter into the flat. Is this correct?
Or what if the meter was within the flat. Then of course you would bond to the meter point, but would you also bond the gas pipes in the common areas?
thanks
thanks
