MCB trips RCD
20 Jun 2009
Yorkshire
Pulled out tumble dryer, and caught tumble dryer cable and shorted it, mcb tripped and rcd, disconnected tumble dryer cable from socket now socket ring main mcb causes rcd to trip after about 5 secs. If I leave this off everything ok. Only seven year old house. No problems before.
Any ideas anyone?
most likely is that you've broken something inside the socket when you yanked on the flex with the TD..
why were you pulling the TD out anyway? this might have bearing on the possibilities..
Changed socket same problem, I am thinking of poss MCB, RCD fault, any thoughts? Don't know enough about these to find out if a short circuit could damage MCB or RCD or is it ring main?
You'll be needing a sparky!!! It could be all sorts of things. plenty of us with spare time in yorkshire :wink:
For it to take 7 seconds I would suspect a neutral - earth fault. And to instruct a DIY person on how to test for a neutral - earth fault has too many bits if not followed to the letter could present danger.
As a result I would advise you get a spark in to do this for you. Especially since the test gear is so expensive and with a fault like this you do want to be sure everything is repaired A1.
Thanks to everyone who replied, It turned out to be the fridge/freezer in the garage!!
The garage socket is connected to the kitchen ring main.
TD must have damaged FF.
Some frost free fridge freezers allow condensation to drain into a tray on top of the compressor, where it is evaporated off during normal operation.
If the power is off for a while, and the fridge starts defrosting, the tray can overflow, dropping water into the electrics :roll:
