We have just had a Remeha 35c installed and it was connected to our existing Honeywell cm927 stat, that previously controlled an old Biasi boiler.
The boilers fine - plenty of hot water hot radiators, no problem there. We do notice that the house gets, I won't say cold, but chilly. The stat in the hallway reads room temp at 21c, other thermometers confirm this is the case in most other rooms as well. But The radiators are always mostly cold, the house is very well insulated, walls loft, double glazed throughout - so I'm assuming it heats up quickly maintains temperature well & the boiler doesn't need to do much once we are up to temperature.
I've read a lot on here & elsewhere about modulating controls and that they operate the boiler at lower output - seems to benefit in gas costs & room comfort. I've also seen that the honeywell opentherm wireless stats aren't available in the uk. We want a modulating control - but we also want to set day & night temperatures, which means a programmable controller. Running a cable isn't an option any more - if we have to have wired - then the controller needs to live by the boiler.
Is there anything out there that would work for us at the moment ?
