    Dismiss Notice
Mono pitched roof ... possible
Discussion in 'Roofing and Guttering' started by ric1982, 25 Jun 2020.
  1. ric1982
    ric1982
    11 Jul 2018
    36
    Thanks Received:
    Country:
    I got a kitchen extension which is 5 meter long and currently has flat roof (which I am sick and tired of it as its leaking all the time + it looks ugly). So I was thinking about replacing it with mono pitched roof but I am not sure given the meaurement if its possible.
    Length of the extension is 5 meter. The extension at the back of the house meaning there is a bathroom window above the extension flat roof. This is about 4 feet above flat roof.
    Can someone please advise if its going to be feasible to have mono pitched roof. My worry is that the gradient is not going to be big enough. (I really dont know how to calculate the angle but it looks very low as the extension is 5 meter long from the house wall).
  2. Sponsored Links
  3. frutbunn
    frutbunn
    22 Jun 2020
    754
    Thanks Received:
    142
    Country:
    depends on the make and type of tiles/slate, lowest I've seen is 12.5 degrees, but I can't remember the make. Are you saying the roof is to be pitched over the full 5m with 4' rise?
    • Thanks Thanks x 1
  4. ric1982
    ric1982
    11 Jul 2018
    36
    Thanks Received:
    Country:
    Yes over full length of 5 meter. Another option is to go side way mono pitch. So from neighbour's side pitch coming down to my side. As the width of the extension is 3 meter can get steep graident. But then there can be a question of planning permission application and blocking neighbours sunlight ?
  5. frutbunn
    frutbunn
    22 Jun 2020
    754
    Thanks Received:
    142
    Country:
    With the dimensions provided you are talking about 12 degrees this includes for 150mm lead flashing, so it is tight and really limits your choice of tile. Another option is to put a water proof deck on the roof and the tiles are aesthetic only, there was a product called Ondutile or Onduline that could be laid first for lower pitches, not seen it in years though. I have accepted a ply sarking board and two layers of roofing membrane depending on location and exposure, but that would be down to the judgement of building control. I used to work right up in the Pennines and I wouldn't accept this approach but have accepted it elsewhere in more kinder climates.
    • Thanks Thanks x 1
  6. Alastairreid
    Alastairreid
    21 Nov 2008
    6,364
    Thanks Received:
    996
    uk
    Country:
    Flat roof 150mm below bathroom window, take it out far enough to get your pitch to wall plate, insulate and weather with lead, epdm or similar.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. datarebal
    datarebal
    1 May 2007
    3,048
    Thanks Received:
    563
    Hampshire
    Country:
    it is do able , the window can be worked round easily to give a decent pitch
    • Thanks Thanks x 1
  9. frutbunn
    frutbunn
    22 Jun 2020
    754
    Thanks Received:
    142
    Country:
    But it always looks ugly.
    • Thanks Thanks x 1
  10. datarebal
    datarebal
    1 May 2007
    3,048
    Thanks Received:
    563
    Hampshire
    Country:
    Not at all
  11. catlad
    catlad
    29 Jul 2011
    4,464
    Thanks Received:
    640
    Lancashire
    Country:
    Smaller bathroom window?
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
