Can you put lightswitches for normal mains lighting circuits in the side of a permanent, built-in cupboard?
Inside the door to the main room there is going to be a floor-to-ceiling cupboard made out of timber and MDF. The obvious place for the lightswitch would be in the side of that cupboard. But can you do that?
I can bury the cable in the wall but was thinking of cutting a single-gang hole in side of MDF, putting in standard metal backbox, then perhaps boxing in with a bit more MDF on the inside. Backbox probably 47mm to house a single-gang with two dimmer modules. MDF probably 18mm thick. Lighting circuit is on a (6A) RCBO.
Is this ok? Any regulations, minimum thicknesses, minimum distances, etcetera?
