Multiple Sockets
19 Jan 2006
Wiltshire
Just wondered if anyone can beat this: Currently I work in an environment where there are 100 x 13a outlets on a single 13a plug.
Anyone beat this?
A picture would be nice :lol:
If will help the insurance people sue the properties team and void the insurance when the place burns down.
Does you firm have any knowledge of health and safety ?
What risk is there ? As long as the 13 amp plug has be fitted with a fuse of 13 amps or less and the cable between it and the outlets can carry 13 amps safely there is no more risk than any other use of a 13 amp plug.
Trip hazard ?
Heat build up from 100 devices ?
So lets say the multi socket extension leads are 4 way.
If the op has 100 'available' sockets and they daisy chain that means 3 sockets as 'available' and one as the daisy chain connect to the next extension lead.
The last lead has 4 sockets to use the rest 3, so that requires 33 leads (32 x 3 + 1 x 4). Each lead is 2m long.
So how would a fire inspector or H&S inspector react to going in to a single room and finding 33 leads connected to 1 x wall socket, and finding 66 m of leads.
I haven't even considered the 100 appliances / devices / wall warts that are load.
I haven't considered the SPF (single point failure)
I haven't considered the possible need for HIE (subject to devices)
It isn't right in a commercial premises or anywhere else to do what's being "boasted" about.
Trip hazard ?
Maximum of about 6 Kwatt ( allowing for the 13 amp fuse carry 26 amps for a short while until it blows
Maybe they are MK double sockets fitted to a 25 foot long wall
But would a ring final or radials with a lot more heat producing capability would be any better ?
Sorry for dragging this one back up! Just checked the replies.
The set up is 5 test benches, each with 10 double sockets - through 1.5mm short runs to 13a plugs into a 5 way trailing socket to the wall mounted 13a twin protected by a 32a MCB & 30mA RCD.
No trip hazards.
All the equipment is low current, but there are are a lot & a power monitor shows pretty low idle draw.
I can arrange piccies!
