How much current do you expect a 240V kettle to draw from a 12V supply?!Plugged stuff like kettles into the charger but that would only draw about an amp
How much current do you expect a 240V kettle to draw from a 12V supply?!Plugged stuff like kettles into the charger but that would only draw about an amp![]()
I was hoping 13amps
You had that design (well - a functionally equivalent one) 5 days and 4 pages ago - think of the time you and everybody else could have saved.....I have set up and tested the above schematic
I have just got a reply too.
I did think you could get relay with duel outputs retail at £7.10 but could not find on internet. From Durite.
Err...I don’t belive we ever had a duel relay circuit
spark123
I've re drawn your schematic Im worried about the load from the pump on to port 87 and there being a positive from live on to port 30 and then onto the float switches
Surly one of them is going to be overloaded
Just wondered why you drew your diagram so the switches wear the other way round
wear are you from
