    Dismiss Notice
New cooker hood - schuko plug??
Discussion in 'Electrics UK' started by Cable Tee, 4 May 2021.
  1. Cable Tee
    Cable Tee
    5 Feb 2020
    11
    Thanks Received:
    Country:
    Hi everyone hope you are all well.
    Just looking for a bit of advice. We recently bought a new cooker hood from a large UK supplier, but when it arrived it had a Schuko plug (it’s bulky and L-shaped, I think maybe “type f”). What is the best thing to do in the situation? We contacted the retailer who said the manufacturer advised we get an electrician to swap out the plugs. Is this our responsibility? Happy to do so if that’s the case, just don’t want to invalidate any warranty!
    Thank you
  2. Sponsored Links
  3. winston1
    winston1
    11 Jan 2010
    6,502
    Thanks Received:
    497
    London
    Country:
    It has been said many times on these forums that cutting a plug off does not invalid the warranty.
    It has also been stated that it is illegal to sell a product in the UK with a foreign plug on it.
    It is up to the retailer to fix it not you. If you want to make an example of him go to trading standards.
  4. Cable Tee
    Cable Tee
    5 Feb 2020
    11
    Thanks Received:
    Country:
    Thank you so much for your reply winston1, I will get back on to them and ask them to sort it out
  5. thomp1983
    thomp1983
    25 Aug 2016
    137
    Thanks Received:
    15
    Country:
    The other issue you may have in this situation is them having to sort it usually results in them refunding you and saying go elsewhere instead of actually getting you the correct product
    • Like Like x 1
  6. securespark
    securespark
    11 Jan 2004
    36,271
    Thanks Received:
    1,221
    Country:
  7. SUNRAY
    SUNRAY
    28 Jul 2009
    4,555
    Thanks Received:
    333
    Kent
    Country:
    Until we left the EU it was not illegal to supply items with Shuko plugs as it was perfectly acceptable to use accessories compliant with any member states wiring regulations.
    I don't know how acceptale existing accessories are now as they could have been fitted when we were a member.
  8. JohnW2
    JohnW2
    28 Jan 2011
    46,840
    Thanks Received:
    3,037
    Buckinghamshire
    Country:
    I may be wrong, but I don't think that ever was the case - as had been said, I think that UK legislation has always required (ever since it required plugs to be fitted) that anything sold in the UK had to be fitted with a BS1363 plug (even if it was one of those 'convertaplug' thingies).
    Kind Regards, John
  9. Cable Tee
    Cable Tee
    5 Feb 2020
    11
    Thanks Received:
    Country:
    this is exactly what they suggested. The manufacturer says it’s apparently not illegal because the manual says it has that type of plug. I haven’t seen that in the manual and how would I know this before purchase? Additionally the retailer says I should find someone because it’s not a service they offer
  10. Sponsored Links
  11. JohnW2
    JohnW2
    28 Jan 2011
    46,840
    Thanks Received:
    3,037
    Buckinghamshire
    Country:
  12. denso13
    denso13
    22 Jan 2007
    4,722
    Thanks Received:
    1,043
    Country:
    Can you wire a plug or know someone who can? Just fit a new plug and be done with it.
    • Like Like x 1
  13. Cable Tee
    Cable Tee
    5 Feb 2020
    11
    Thanks Received:
    Country:
    I can, I was just a little weary initially because I didn’t know if there were any warranty issues. Oh well, I think I’ll just fit a new plug on it :)
    • Like Like x 1
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,840
    Thanks Received:
    4,002
    Retired to:
    Country:
    Portugal
    Send them a bill for having a Schuko socket fitted.
  15. sparkwright
    sparkwright
    20 Aug 2009
    8,285
    Thanks Received:
    1,030
    Dorset
    Country:
    Do you even have a socket nearby to plug this thing in?
    Some cooker hood arrangements have a junction box (typically fed from a switched FCU unit somewhere) that you would wire into.
  16. IJWS15
    IJWS15
    18 Oct 2006
    1,392
    Thanks Received:
    49
    Staffordshire
    Country:
    I have an extension lead with a European plug on one
    end and a UK socket on the other so she can plug her hairdryer in when we are abroad.
    I am sure amazon (there are other retailers) will have convertors
  17. Cable Tee
    Cable Tee
    5 Feb 2020
    11
    Thanks Received:
    Country:
    We have a socket in the wall specifically for the cooker hood, it was mapped into the kitchen design. It will have to be a plug we use rather than junction box arrangement
    I think an adapter will be good but I’m not sure which is a reputable place. I looked on TLC but they didn’t seem to carry it online
Loading...
Share This Page
