    Dismiss Notice
Old electrical board - will I get an EICR
Discussion in 'Electrics UK' started by benjiman, 31 Aug 2021.
  1. benjiman
    benjiman
    21 Jul 2004
    346
    Thanks Received:
    3
    Country:
    Got a 1 bed flat with old electrical board. If I got an electrician in would they insist on a new installation if I was renting out the property or would it still pass as it is if after the inspection everything is hunky dory?
    TIA.
  2. Sponsored Links
  3. motorbiking
    motorbiking
    31 May 2016
    6,815
    Thanks Received:
    771
    Country:
    Highly unlikely.
    • Thanks Thanks x 1
  4. flameport
    flameport
    10 Mar 2007
    9,923
    Thanks Received:
    1,988
    Poole, Dorset
    Country:
    That has been in need of a new consumer unit for a couple of decades.
    An EICR is a report on the condition of the installation, if you pay you will get one. It will state Satisfactory or Unsatisfactory.
    In it's present state it will be Unsatisfactory, as there are no RCDs for any of the circuits, those thin exposed red/black wires should not be there, neither should the dodgy joint halfway along the red one, the earthing arrangement is questionable or non-existent and both the incoming supply and the tails to the existing consumer unit look like ancient decaying rubber.
    There may be other problems elsewhere.
    Before any of that, please remove all of the paper and other flammable junk in there, the warning label stating not to store flammable materials is there for a reason.
    • Thanks Thanks x 1
    • Like Like x 1
  5. AndyPRK
    AndyPRK
    4 Jan 2009
    5,887
    Thanks Received:
    593
    Herefordshire
    Country:
    The tails look old.
    Where is the earth.
    time for an upgrade
    • Thanks Thanks x 1
  6. benjiman
    benjiman
    21 Jul 2004
    346
    Thanks Received:
    3
    Country:
    Thanks guys. So with there being no earth from the mains supply is it best to call the supply company to come and sort that or call an electrician first to take a proper look?
  7. AndyPRK
    AndyPRK
    4 Jan 2009
    5,887
    Thanks Received:
    593
    Herefordshire
    Country:
    Probably a spark.
    you could call the supply company and ask if they are able to supply a PME and if any charge
    • Thanks Thanks x 1
  8. Sponsored Links
  9. flameport
    flameport
    10 Mar 2007
    9,923
    Thanks Received:
    1,988
    Poole, Dorset
    Country:
    Electrician first.
    If there is a problem with the earth, then it will probably be a problem for the whole building, and is likely to be the responsibility of whoever manages/maintains it. Network operator / DNO responsibility most likely ends at the intake room.
  10. AdrianUK
    AdrianUK
    22 Sep 2009
    611
    Thanks Received:
    91
    Nottinghamshire
    Country:
    The MEM single switchfuse (small brown square one) is intriguing....
    The WYLEX skeleton consumers unit with its built-in meter cupboard post dates the MEM by a good 10 years... whats it doing in there?
  11. OwainDIYer
    OwainDIYer
    5 May 2010
    4,555
    Thanks Received:
    698
    Stirlingshire
    Country:
    MEM was probably added later for an electric shower. Someone doing a cheap job with whatever someone else was throwing out?
  12. AdrianUK
    AdrianUK
    22 Sep 2009
    611
    Thanks Received:
    91
    Nottinghamshire
    Country:
    Nah, those little switchfuses pre-date electric showers by a few decades. They contain a single porcelain BS3036 rewireable fuseholder rated at, I think, 15A max.
  13. JohnD
    JohnD
    15 Nov 2005
    74,250
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    there are a few sizes of them, but I think that small black one is 15A. Later ones were gloss grey. It may have an asbestos pad in the fuse assembly. might be/have been immersion heater or shed.
    I once had a house where one of those was the newest (!) electrical equipment in the house, the rest of it was condemned, and I used its socket for wanderleads and builders outlet until rewired.
  14. AndyPRK
    AndyPRK
    4 Jan 2009
    5,887
    Thanks Received:
    593
    Herefordshire
    Country:
    I think I have one with 30a fuse
Loading...
Share This Page
