I need to move the oven switch 6" further away from the incloming feed (new bigger oven), the exisitng cable is not long enough!
What are my options? The work I am doing will be certified and replacing the whole cable is NOT an option??
The oven is a dual fuel model, max rating at 7.4kW, so 30A and 4mm is OK then?
I would like to use some ceramic 30 amp choc block in a recessed back box, ceiling height and run the new cable down to the oven switch.
What do the regs say?? Replacing the whole cable would require destruction of a £3k floor so that aint happening!
Many Thanks,
Matt.
Many Thanks,
Matt.
