- Joined
- 16 Aug 2021
- Messages
- 4
- Reaction score
- 0
- Country
Hello
Sorry if this is a stupid question but I'm a DIY newbie: I'm replacing curtain pole brackets as our previous brackets have bent under the weight of the curtains. I've removed the old brackets - There weren't any plugs in the wall apart from one very large metal (potentially self-drilling) plug that has left a 10mm hole. The wall behind is dot and dab.
I need some guidance on how to replace the brackets with the following specific questions:
1. Can I reuse the holes from the previous brackets?
2. Which wall plugs would be best to use? Does it make a difference if I reuse the previous holes vs making new holes?
3. Can I use pollyfilla to fill the larger hole and then reuse it? If so, does that change the type of plug I can use?
Thank you so much in advance!
