I have a powermax 135. CH stopped on Fri. Hw working Ok.Pump hot and also slight leak.Changed pump also isolating valve either side as they decided to leak when turned off so had to drain down and refill.Restarted and burner ran until water was hot.Then nothing.Burner will not fire at all even on continuous setting.No voltage on pump when CH selected.Display on clock looks ok.Tried restting clock (enter and minus) no joy.Have voltage between "Heating on" terminal and neutral on back of clock when CH is selected.Does anyone have any ideas?
