Parapit roofs, lead roses, glazing those were the days.
Still turn my hand when needed,recently done a 12 metre long 1 metre wide box gutter,loved it,the smell the feel the lack of urgency.that's what it was about.
To top it off,ended up showing(reminding) my md how to wipe a joint on a boiler swap we did.
I did something like this years ago. It was called JIB.
I came 5th.
I would had got 3rd if I got the 42mm copper pipe filled with sand and heat up till I can bend it right. I thought it was alright till I was told it need to be tight bend.
The job is fit a basin, a bidet, run copper pipes with solder ring, brazed joints, steel pipes with thread joints and welded joints.
