Re: Picture of the week!™
11 Jan 2004
Well folks, it's that time of the week again!
It's goodbye from him and hello from me!
Yes, for the next two weeks only, I have been asked to take over this slot.
It will be tricky filling the Maestro's shoes, but I'll try my best. :wink:
So here goes...
This week I am chancing my arm & posting 2 pairs of photos here.
Apologies for the poor quality: I only had a 1MP cam with me.
The first are pictures of dodgy-looking fuse carriers I removed from a Wylex Standard board.
The second pair were taken today at a fairground.
Don't you just love fairground electrics :lol:
(that isn't my handywork by the way - I have helped a mate out before that is associated with the local fair). Definately an eye opener!
The 30A cartridge fuse had fusewire wrapped round it nearly three times, while the 5A fuseholder had a BS1362 13A fuse in it. These are longer than 1361's and you can see from the picture that the blades are pushed out of their intended position. In fact, it would not fit the fuse shield, so it had been broken so the fuse carrier would fit...
What you can't see from the piccy (unfortunately) is that there was a 15A fusewire bridging the blown 13A fuse which had also vapourised. There was only one lighting circuit in the property and every room had had extensive lighting additions: multi-lamp fittings or many recessed spots where only a rose had existed. Also, 500W floodlights outside...
Of the fairground piccys, the first was an exposed choc block joint on a ride, completely accessible to the public. In fact, the block was resting on the chassis of the trailer to which the ride was attached and I got a worker to move it away.
The second is of a 4 way extension socket on a "hook a duck" stall where the flex cores are hanging out of the body of the socket. The unit is sited below a pump inlet/outlet arrangement for the stall and water is dripping on the socket.
Fairground ride probably would be grounded too! Could work off 110v DC, have seen a few like that.
There was a mixture of yellow & blue arctic hanging around, sometimes connected to each other...
From my limited snooping, I gathered most stuff was running 110 AC.
Still a pretty poor do, mind!
