    Dismiss Notice
Replaced Fluorescent Tube now lights upstairs don't work
Discussion in 'Electrics UK' started by rvp, 2 Apr 2021.
  1. rvp
    rvp
    26 Jan 2013
    197
    Thanks Received:
    3
    Manchester
    Country:
    Posting on behalf of my father in law.
    Firstly I don't intend to mess about with it and I didn't fit it either just to be clear.
    Yes they should get a sparky out but I am thinking it's relatively straightforward!
    OK here is the story.
    The Fluorescent Tube stopped working and was replaced with a complete new unit which now works fine.
    They found the lights upstairs now don't work plus the other light in the kitchen doesn't either, guessing the upstairs and the non working light in the kitchen are on the same circuit.
    The lights in the kitchen have their own separate switches to turn on/off, these have not been tampered with.
    Fuse box is very old with the ancient copper wire fuses that plug in!
    Any ideas?
    Cheers!
  2. Sponsored Links
  3. ETAF
    ETAF
    24 Apr 2008
    1,171
    Thanks Received:
    204
    UK, Wittering, West Sussex
    Country:
    who replaced the unit - ITS possible the lights are daisy chained so the power goes into the fluorescent light and then taken out to go to next light - although - I would have expected upstairs/downstairs usually on own fuses -
    who changed the light fitting ?
    Where is the new tube and where are the other rooms - not sure on whats upstairs or downstairs
    on the FUSE Box - maybe some White dots on the fuse holder - how many do they have
    NOT A current electrician, - so maybe wrong, and other may assist - But maybe useful to provide the info
    • Thanks Thanks x 1
  4. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    Sounds most probably like a bad connection in the new light has caused the remaining light to stop working. It would certainly be my first place to look. Also be aware that even though the lights are not working they may still be live so proper proving for dead is even more essential before working on any of the installation.
    • Thanks Thanks x 1
    • Like Like x 1
  5. rvp
    rvp
    26 Jan 2013
    197
    Thanks Received:
    3
    Manchester
    Country:
    Thanks people, as to who fitted it I believe it was stevie wonder! Seriously it was a friend of a friend apparently!!
  6. Sponsored Links
  7. ETAF
    ETAF
    24 Apr 2008
    1,171
    Thanks Received:
    204
    Country:
    Are you going to get Stevie wonder back ? OR look yourself
    • Like Like x 1
  8. rvp
    rvp
    26 Jan 2013
    197
    Thanks Received:
    3
    Manchester
    Country:
    I don't intend to tbh! although I may have a peek at the wiring in the fitting to see if there is any obvious issues.
    I just remembered he also told me he used longer screws to fix the fitting to the ceiling so maybe he's damaged the circuit wiring for upstairs, also there is no place for the earth for the new fitting like the old one hmmm plot thickens!
  9. ETAF
    ETAF
    24 Apr 2008
    1,171
    Thanks Received:
    204
    Country:
    depends on the fitting , it maybe a double insulated replacement a BOX within a BOX is the symbol
    do a search on google images for Double Insulated
    • Thanks Thanks x 1
  10. 333rocky333
    333rocky333
    12 Jan 2008
    8,426
    Thanks Received:
    902
    Essex
    Country:
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
