(the coloured fuse shields should not need changing, as the cartridge fuse shields are the same as the breaker shields). Turn the supply back on - job done.
Regarding the WYLEX
I dont think they are actually, the base for mcbs are different thickness to the fuse bases, and will affect how far the pins go into the blades
Its poor advise to change just one part.
If rewire-able fuses the bases need changing.
If cartridge fuses you may not need to change bases
so far i have to assume they are cartridge, that was pointed out to me in an earlier post
havent had one out yet...and if they are rewireable i definately want them replaced
i cant fault the information i get her...thanks to all greatly
geof
Regarding the WYLEX
Again regarding WYLEX
Maybe
You would not know that till you remove the base and check, who knows someone prior may of left a fuse base in prior to the cartridge head.
Seen it in pubs were laziness has left breakers protruding different lengths
The new head and base are matched to allow the correct length of fork into the blades.
What advantage is there not to change both, the supply should be isolated first anyway,so low hazard risk, rather than leaving a wrong base creating an unnessacary fire risk
Ps wheres spell check nowadays![]()
i understood it perfiktlay
